mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
mtg1974
Jan 02, 2016Initiate
I assumed that you meant the firmware update zip file. I downloaded it and upgraded my router but there is still a language update.
thelemonkid
Jan 03, 2016Luminary
Same issue!!!
