mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
Anonymous
Jan 03, 2016Seems to be a repeatable bug. Not sure it would matter at all if the 'new' GUI update worked.
- JamesGLJan 04, 2016NETGEAR Employee Retired
Hi All,
Mine works fine after the update to the latest version. Please try the suggestion of Searay in updating or loading the firmware manually.
- AnonymousJan 04, 2016
The manual update did not fix the issue. Checking for update still shows GUI language update available. Just a nit, as there doesnt seem to be any problems other that that message.
