mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
Retired_Member
Jan 03, 2016Seems to be a repeatable bug. Not sure it would matter at all if the 'new' GUI update worked.
JamesGL
Jan 04, 2016NETGEAR Employee Retired
Hi All,
Mine works fine after the update to the latest version. Please try the suggestion of Searay in updating or loading the firmware manually.
- Retired_MemberJan 04, 2016
The manual update did not fix the issue. Checking for update still shows GUI language update available. Just a nit, as there doesnt seem to be any problems other that that message.
