mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
Placebo
Jan 05, 2016Aspirant
Ditto here.
I upgraded using the manual method with the zip file from the Netgear website, and did a reset after upgrading. However the router still shows a GUI language update
JamesGL
Jan 05, 2016NETGEAR Employee Retired
Hi All,
Can you provide screenshot of the GUI language update?
What web broswer did you use to access the UI?
- PlaceboJan 05, 2016Aspirant
Hi, after seeing your question I decided to try another web browser and have now performed the GUI language update successfully.
Originally I was using Chrome, but then I switched to Safari. So my advice would be to try another web browser and report back.
- mtg1974Jan 05, 2016Initiate
I've been useing Chrome (47.0.2526.106 m). I performed the upgrade last night and it worked without doing anything special. I'm guessing that Netgear fixed something.
- HarmVeenstraJan 05, 2016Aspirant
Same here, failed before the last few days and it does work now. Updates, reboots and doesn't say it has the same update again
- JamesGLJan 05, 2016NETGEAR Employee Retired
Hi All,
