mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
JamesGL
Jan 05, 2016NETGEAR Employee Retired
Hi All,
Can you provide screenshot of the GUI language update?
What web broswer did you use to access the UI?
mtg1974
Jan 05, 2016Initiate
I've been useing Chrome (47.0.2526.106 m). I performed the upgrade last night and it worked without doing anything special. I'm guessing that Netgear fixed something.
- HarmVeenstraJan 05, 2016Aspirant
Same here, failed before the last few days and it does work now. Updates, reboots and doesn't say it has the same update again
- JamesGLJan 05, 2016NETGEAR Employee Retired
Hi All,
- mcloakedJan 05, 2016Tutor
I had always been using Chrome x86_64 in linux, fully updated. I have just tried again and it works fine - so it does indeed look as if there was some internal file error at the netgear website from where the update is provided. It would be interesting to know what the problem was and what change was made on the Netgear servers to fix the bug? Either way this issue is now resolved.
