WayneD214
Jan 26, 2022Aspirant
R7000, Fiber (CenturyLink) and router switch
I have a Netgear R7000/AC1900 router, I'm trying to plug in the ethernet cable that goes into the CenturyLink router that has the connection to fiber. I would like to replace the CenturyLink router ...
- Feb 09, 2022
michaelkenward
Jan 27, 2022Guru - Experienced User
You are trying to plug the R7000 into the CenturyLink router?
Tiy shgoukd be able to plug the R7000 into whatever CenturyLink uses to deliver the Internet to you. What is that?
Remember, you don't just plug the router into the Internet. You turn the router on after you plug it in. And you should reset the router before you connect it to a different Internet service. You need to get it to forget any past settings.
WayneD214
Jan 27, 2022Aspirant
I'm trying to eliminate the CenturyLink/Quantum router. I talked to them (Century Link)
a month or so ago and they said that VLAN tagging DHCP not PPOE. I was also
reading through forum posts and I noticed some folks said to switch the mode to
"router" from "bridge"(??)
