WayneD214
Jan 26, 2022Aspirant
R7000, Fiber (CenturyLink) and router switch
I have a Netgear R7000/AC1900 router, I'm trying to plug in the ethernet cable that goes into the CenturyLink router that has the connection to fiber. I would like to replace the CenturyLink router ...
- Feb 09, 2022
WayneD214
Feb 09, 2022Aspirant
michaelkenward wrote:
WayneD214 wrote:
The last time I talked to CenturyLink tech support they mentioned VLAN TAGGING and DHCP over PPOE. Are there other things that need to be found out for how to substitute the AC1900 for the CenturyLink?
> We have been through all this several times.
Yes we have
> You seem happy to listen to friends and your ISP while ruling out things
> that people have suggested here.
I have read and considered everything mentioned here. My friends haven't said anything. I'm going simply from what I've been able to gather in talking and reading from various sources including the tech from the ISP.
> As you don't seem to accept that "double NAT" is a real issue, there
> really isn't much more that anyone can suggest.
Double NAT is an issue, I don't think I've ever doubted that, that is why I'm tryng to eliminate the CenturyLink router. I've done some more searching and come across a setting that seems to be relevant, on the CenturyLink router is a setting marked as VLAN=201. There is a similiar setting for the netgear router, login to the router, go to the Advanced tab, navigate to the VLAN section and there are two boxes, VLAN ID & Priority. I tried entering 2, 20 and 201 in those boxes with no success. I don't know what to enter as a priority?
michaelkenward
Feb 09, 2022Guru - Experienced User
