KBol
Mar 14, 2019Aspirant
R7000 Firmware update failure
R7000 - FIRMWARE WON'T UPDATE USING THE APP. ROUTERLOGIN.NET WON'T ACCEPT SERIAL NUMBER, HOW DO I EXECUTE DOWNLOADED FIRMWARE UPDATE?
- Mar 14, 2019
if its asking for the serial number, you're going through the forgot password option. You might have to reset to factory defaults and log in, do your upgrade, and then re-setup the router.
KBol
I can log in an bring up the GUI but it does not recognize my serial number and so I cannot advance to the next screen.
Mar 14, 2019Guru - Experienced User
- KBolMar 14, 2019Aspirant
Thank you very much. The factory reset worked and I then was able to access the Genie platform and complete the update. I really appreciate your assistance.
