LowellBen
Oct 18, 2022Aspirant
R7000 firmware update issue
I've got an R7000 with the auto firmware update enabled. Router is running firmware version V1.0.11.100... Netgear support says that the latest firmware is V1.0.11.136.... So first off the auto u...
- Oct 18, 2022
What browser are you using? Try MS Edge or Firefox.
Be sure to clear out ALL browser caches prior to entering the routers web page.
Might try a factory reset and setup from scratch with the router disconnected from the ISP modem. Then load the .chk FW file to the router using the manual tab on the FW update menu section.
Oct 18, 2022Guru - Experienced User
- LowellBenOct 20, 2022Aspirant
Sorry for the delayed reply. Thought the system would send me an email when there was a response.
I'm running Opera as the browser.
And you were EXACTLY correct. I switched to MS Edge and the router loaded the 136 firmware with no issue.
Thanks ever so much for the help!!!
Lowell
- FURRYe38Oct 21, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
