RonFL
Mar 19, 2020Guide
R7000 firmware update killed my download and upload speed
A few days ago, I received a sales-related email from NetGear and while skimming through the ad learned that NetGear Genie had been replaced by the Nighthawk App, which I downloaded to my Iphone. On...
- Mar 20, 2020
RonFL wrote:
How do I back-up my router settings?
Check the manual.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation, and, if there are any, firmware versions and drivers for your hardware.
See the section in the manual Manage the Router Configuration File and the bit Back Up Settings.Best done through the browser interface.
michaelkenward
Mar 20, 2020Guru - Experienced User
Check the manual.
Support | NETGEAR
RonFL
Mar 22, 2020Guide
This seems to have worked. The factory reset after the firmware downgrade/rollback has brought my download speed back to 225mps-245mps, and upload is back to 11.7mps-12.2mps. I haven't clicked on "solution" just yet though, because now the Nighthawk app on my Iphone and the Genie app on my desktop PC no longer identify the devices connected to the R7000 router, and only identify them as "unknown" in the Nighthawk app, and with a generic icon and a question mark in the Genie app on my desktop, when I use to get an icon resembling what the device was (pc, tablet, phone, google or amazon speaker, etc.) and the device's official device name (from the device, not something manually entered). I know it seems trivial now that I have my internet speed back, but I use the Nighthawk app to turn off router/internet access to certain devices (I have teenagers) at certain times, so I need to be able to know which devices are on so I know which I want to turn off access for. Refreshing the apps doesn't resolve the issue, neither does logging out and logging back in. Do I need to delete the Nighthawk app in favor of the Genie iOS app it replaced (assuming I can still get it in the app store)? Any other suggestions welcomed ......
- michaelkenwardMar 22, 2020Guru - Experienced User
That won't work. The Nighthawk app replaces the Genie. It is not an alternative.
- RonFLMar 23, 2020Guide
Ok, then suggestions on what may work or what to try so I can actually see and tell what devices are connected in the Nighthawk app and the Genie desktop app would be appreciated ......
- labattMar 23, 2020Mentor
Getting accurate connected devices has been broken in various firmwares for over a year.
