Sezro626
May 26, 2021Guide
R7000 Firmware Update?
I have been having WiFi issues daily. It cuts out sometimes multiple times a day. Is there an easy way to update the firmware? I'm currently using v1.0.9.88_10.2.88 I would like to restore it to a pr...
- May 26, 2021
I'd highly recommend against the app.
When we see corrupt firmware issues, it tends to be when people update via the app or via wifi.
here's what I'd recommend. And to use a wired connection. Just my thoughts.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Sezro626
May 26, 2021Guide
I will try to update to the latest version through the app. I think last time it didn't work. plemans
May 26, 2021Guru - Experienced User
