yynsums
Sep 23, 2021Follower
R7000 Firmware update
Try to update the firmware the first time, how can i open the .chk file?
- Sep 23, 2021
You don't open the chk file, you flash it. Go to http://routerlogin.net or http://192.168.1.1 and in the Advanced settings you can flash it. (Advanced -> Administration -> Firmware Update)
microchip8
Sep 23, 2021Master
Sep 23, 2021Guru - Experienced User
microchip8 is right. you don't open the file. Follow the guide microchip8 wrote or follow the netgear manual update process.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- michaelkenwardSep 25, 2021Guru - Experienced User
If you want the official line, that is actually a link to Neatgear's own guidance on the process:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
