jbnye
Feb 08, 2016Aspirant
R7000 firmware upgrade installed new "arlo" network?
I recently installed a firmware upgrade after receiving an email reminder from Netgear. Previously, I had two networks -- NETGEAR91 and NETGEAR91-5G. Since the firmware upgrade, my IOS devices are ...
- Feb 08, 2016
Yes. There's a new setting where you can disable it, too.
jbnye
Ah, yes, now I see several related threads about this. I've unchecked the "enable arlo" box. Hopefully this will also resolve why my ipad's wifi connection suddenly seemed to have gone flaky.
Thanks for the quick reply!
Retired_Member
Feb 08, 2016The fix is to revert to 4.30 if you have ANY further problems.
