chappcc
Dec 13, 2016Tutor
R7000 Firmware upgrade to V1.0.7.6
I downloaded and applied the recent firmware update V1.0.7.6_1.1.99. All seemed to go well, except after logging on to the router, the older version is still shown as V1.0.4.30_1.1.67 and the I see ...
- Dec 13, 2016
Downloaded again and re-flashed. Now the router screen shows the proper version and no indication of an available update.
Unfiltered1
Dec 13, 2016Tutor
My R7000 shows version 1.0.7.6_1.1.99 after flashing the beta firmware. No indication of an update available and all is working without issue so far.
chappcc
Dec 13, 2016Tutor
- fancyladyDec 13, 2016Aspirant
I am currently manually downloading the beta firmware for R7000. Everything looked good and I then when my status bar got to the rebooting the router's firmware, I got a pop-up screen saying AUTHENTICATION REQUIRED Your connection to this site is not private. It wants me to input my username and password again. Did you guys have to re-enter your password at this stage? I never have in the past, so I am just sitting here not knowing what to do..................
Do I enter user name and password or cancel everything?
- mdgm-ntgrDec 13, 2016NETGEAR Employee Retired
I would suggest that you re-enter your username and password and see where it is at.
- chappccDec 18, 2016Tutor
I want to amend my response. While the router seems to be working properly, I've noticed a decline in performance, both with wired and wifi connections. I get a noticeable delay when connecting to web pages and periodic delays/interruption when downloading files (such as os updates). Have any others experienced performance issues? I performed a speed test and once it started it seemed fine. It is just delays in getting response to web pages and a pauses in downloads that I am concerned about. Here is my speed test result:
- jguerdatDec 18, 2016Guru
Maybe related, maybe not. My Arlo Q camera uses the 5Ghz band and won't connect if speed is set to above 600Mbs. Might be worth a try.
- LornyJan 08, 2017Aspirant
Same problem after V1.0.7.6_1.1.99 update. Internet super slow on all connected devices and pings/latencies are through the roof. Pings are all over the map as well. from 24ms to 860ms on subsequent tests. What have you done to my beautiful router, Netgear?
- xealoJan 08, 2017Aspirant
I'm having the same exact issue. This router has been bulletproof since I bought it back in 2013. I've performed a clean install and I'm still losing WAN connectivity.
