chappcc
Dec 13, 2016Tutor
R7000 Firmware upgrade to V1.0.7.6
I downloaded and applied the recent firmware update V1.0.7.6_1.1.99. All seemed to go well, except after logging on to the router, the older version is still shown as V1.0.4.30_1.1.67 and the I see ...
- Dec 13, 2016
Downloaded again and re-flashed. Now the router screen shows the proper version and no indication of an available update.
chappcc
Dec 13, 2016Tutor
fancylady
Dec 13, 2016Aspirant
I am currently manually downloading the beta firmware for R7000. Everything looked good and I then when my status bar got to the rebooting the router's firmware, I got a pop-up screen saying AUTHENTICATION REQUIRED Your connection to this site is not private. It wants me to input my username and password again. Did you guys have to re-enter your password at this stage? I never have in the past, so I am just sitting here not knowing what to do..................
Do I enter user name and password or cancel everything?
- mdgm-ntgrDec 13, 2016NETGEAR Employee Retired
I would suggest that you re-enter your username and password and see where it is at.
