chappcc
Dec 13, 2016Tutor
R7000 Firmware upgrade to V1.0.7.6
I downloaded and applied the recent firmware update V1.0.7.6_1.1.99. All seemed to go well, except after logging on to the router, the older version is still shown as V1.0.4.30_1.1.67 and the I see ...
- Dec 13, 2016
Downloaded again and re-flashed. Now the router screen shows the proper version and no indication of an available update.
road3682
Dec 17, 2016Aspirant
jguerdat
Dec 17, 2016Guru
I find that the Respond to Ping on Internet port is enabled but grayed out. Everything else is fine. Is this true for anyone else or am I lucky?
- Retired_MemberDec 17, 2016
Mine is unchecked, I reset to defaults, did you?
- jguerdatDec 17, 2016Guru
Nope, guess I'll have to. Thanks for the confirmation.
You're welcome,
- jguerdatDec 18, 2016Guru
Huh. I just checked again and find that even though my reset yesterday showed that the Internet ping was disabled, it's back again and grayed out.
Ok, found out why this is. If the VPN service is enabled, theRespond to Ping on Internet port is enabled but grayed out. Disable VPN and all is well.
Without knowing the ins and outs of how the VPN service has to work, is this actually necessary?
