chappcc
Dec 13, 2016Tutor
R7000 Firmware upgrade to V1.0.7.6
I downloaded and applied the recent firmware update V1.0.7.6_1.1.99. All seemed to go well, except after logging on to the router, the older version is still shown as V1.0.4.30_1.1.67 and the I see ...
- Dec 13, 2016
Downloaded again and re-flashed. Now the router screen shows the proper version and no indication of an available update.
jguerdat
Dec 17, 2016Guru
I find that the Respond to Ping on Internet port is enabled but grayed out. Everything else is fine. Is this true for anyone else or am I lucky?
Retired_Member
Dec 17, 2016Mine is unchecked, I reset to defaults, did you?
- jguerdatDec 17, 2016Guru
Nope, guess I'll have to. Thanks for the confirmation.
- Retired_MemberDec 17, 2016
You're welcome,
