chappcc
Dec 13, 2016Tutor
R7000 Firmware upgrade to V1.0.7.6
I downloaded and applied the recent firmware update V1.0.7.6_1.1.99. All seemed to go well, except after logging on to the router, the older version is still shown as V1.0.4.30_1.1.67 and the I see ...
- Dec 13, 2016
Downloaded again and re-flashed. Now the router screen shows the proper version and no indication of an available update.
Oilburner
Dec 17, 2016Aspirant
Updated mine and my trio of Trane XL950 Thermostats won't connect. Rebooted the router and the thermostats, but no joy. Haven't rolled back the firmware to troubleshoot yet as I figured I would see if anyone else experiences similar issues first.
Retired_Member
Dec 17, 2016Did you try deleting the connnection in the stat(s)? If XL 950 is anything like the XL 824 a factory reset does wonders AS long as you understand the serviceman setup.
Nexia is another lame company. If using remote app stop and restart app
- chappccDec 17, 2016Tutor
I have a Honeywell Wifi thermostat and have no issues connecting after the upgrade.
- OilburnerDec 17, 2016Aspirant
I haven't done a factory reset yet - I will have to walk alll three menus and write everything down. All three systems are different from one another, so the set-ups vary significantly.
All three are heat pumps, two are dual fuel.
The other 14 devices have no problems.
Grrr.....
Powered the router down and restarted. That did the trick!
Reboots always worked before. Weird.
- Retired_MemberDec 17, 2016
About 15 mins ago I picked up my iPhone and to my surprise My Trane XL824 wasn't connected either. I was able to re-connect again from stat and all is good.
R8500
