chappcc
Dec 13, 2016Tutor
R7000 Firmware upgrade to V1.0.7.6
I downloaded and applied the recent firmware update V1.0.7.6_1.1.99. All seemed to go well, except after logging on to the router, the older version is still shown as V1.0.4.30_1.1.67 and the I see ...
- Dec 13, 2016
Downloaded again and re-flashed. Now the router screen shows the proper version and no indication of an available update.
Retired_Member
Dec 17, 2016Did you try deleting the connnection in the stat(s)? If XL 950 is anything like the XL 824 a factory reset does wonders AS long as you understand the serviceman setup.
Nexia is another lame company. If using remote app stop and restart app
chappcc
Dec 17, 2016Tutor
I have a Honeywell Wifi thermostat and have no issues connecting after the upgrade.
