chappcc
Dec 13, 2016Tutor
R7000 Firmware upgrade to V1.0.7.6
I downloaded and applied the recent firmware update V1.0.7.6_1.1.99. All seemed to go well, except after logging on to the router, the older version is still shown as V1.0.4.30_1.1.67 and the I see ...
- Dec 13, 2016
Downloaded again and re-flashed. Now the router screen shows the proper version and no indication of an available update.
Libnaz1349
Dec 18, 2016Aspirant
I don't have a computer. Only iPhone & iPad. How can I upgrade the firmware for R7000
- HiSpeedDec 19, 2016Guide
Libnaz1349 wrote:I don't have a computer. Only iPhone & iPad. How can I upgrade the firmware for R7000
It's very risky to change a router firmware wirelessly, you can brick it.
As mdgm said, you should use a wired PC (from a friend for example)...
