Miked2
Jan 08, 2022Apprentice
R7000 Firmware Version 1.0.11.130 - Just showed up Jan 6, 2022
The release notes say only: Fixes security vulnerabilities. Anyone tried this one? I am afraid... But, I always hope they fix some of the other ongoing stuff, like the Attached Devices list m...
Scupper1
Jan 15, 2022Guide
Will do.
Scupper1
Jan 16, 2022Guide
After 48 hours and two reboots just to check, everthing seems good.
All the devices are visible in the GUI and Nighthawk app (Android).
Only glitch I can see is one Apple iPhone shows up, but without it's name.
- FURRYe38Jan 16, 2022Guru - Experienced User
Dissble the Private Address feature on the phone, then the right host name for the phone will appear.
- Miked2Jan 16, 2022Apprentice
HI:
With your encouragement, I rebooted and applied the 130 firmware (no reset). So far all good and all devices show in the attached devices list. Maybe they actually fixed something? If all goes bad, I will just blame you ;-)
Thanks
- Bill-DJan 16, 2022Apprentice
I've been on '130 for 24 hrs. Seems Ok, so far. I edited a device name in the Attached Devices list and the router immediately refused any further browser access, but it kept routing. A power-cycle reboot restored its browser access and I saw my device name edit was successfully. So, I guess you could rename devices if you were willing to suffer through a reboot with each edit. Maybe that's NG's big security improvement - requiring a reboot after each edit ::smileyvery-happy:
So, I had to try. I edited an item in the device list, and the exact same result, the router refused access, unti I rebooted it. Figures Netgear cant actually do anything totaly right!
It gets worse. Without making any more edits, I came back later and again couldn't access it from my browser. Had to reboot again to regain access. Later, I came back a 3rd time and browser access worked. Go figure!
