Miked2
Jan 08, 2022Apprentice
R7000 Firmware Version 1.0.11.130 - Just showed up Jan 6, 2022
The release notes say only: Fixes security vulnerabilities. Anyone tried this one? I am afraid... But, I always hope they fix some of the other ongoing stuff, like the Attached Devices list m...
Jan 16, 2022Guru - Experienced User
Dissble the Private Address feature on the phone, then the right host name for the phone will appear.
Scupper1 wrote:
After 48 hours and two reboots just to check, everthing seems good.
All the devices are visible in the GUI and Nighthawk app (Android).
Only glitch I can see is one Apple iPhone shows up, but without it's name.
Miked2
Jan 16, 2022Apprentice
HI:
With your encouragement, I rebooted and applied the 130 firmware (no reset). So far all good and all devices show in the attached devices list. Maybe they actually fixed something? If all goes bad, I will just blame you ;-)
Thanks
