Miked2
Jan 08, 2022Apprentice
R7000 Firmware Version 1.0.11.130 - Just showed up Jan 6, 2022
The release notes say only: Fixes security vulnerabilities. Anyone tried this one? I am afraid... But, I always hope they fix some of the other ongoing stuff, like the Attached Devices list m...
Bill-D
Jan 16, 2022Apprentice
Scupper1 wrote:After 48 hours and two reboots just to check, everthing seems good.
All the devices are visible in the GUI and Nighthawk app (Android).
Only glitch I can see is one Apple iPhone shows up, but without it's name.
I've been on '130 for 24 hrs. Seems Ok, so far. I edited a device name in the Attached Devices list and the router immediately refused any further browser access, but it kept routing. A power-cycle reboot restored its browser access and I saw my device name edit was successfully. So, I guess you could rename devices if you were willing to suffer through a reboot with each edit. Maybe that's NG's big security improvement - requiring a reboot after each edit ::smileyvery-happy:
Miked2
Bill-D wrote:Scupper1 wrote:After 48 hours and two reboots just to check, everthing seems good.
So, I had to try. I edited an item in the device list, and the exact same result, the router refused access, unti I rebooted it. Figures Netgear cant actually do anything totaly right!
- Bill-DJan 16, 2022Apprentice
It gets worse. Without making any more edits, I came back later and again couldn't access it from my browser. Had to reboot again to regain access. Later, I came back a 3rd time and browser access worked. Go figure!
- FURRYe38Jan 16, 2022Guru - Experienced User
I would either power OFF the router for 1 minute then back ON, or factory reset and setup from scratch maybe needed.
- Miked2Jan 16, 2022Apprentice
FURRYe38 wrote:I would either power OFF the router for 1 minute then back ON, or factory reset and setup from scratch maybe needed.
Power cycle done...
I thougtht I got away with a clean and easy firmware update, no reset required. Now I remember why I hate this product so much?!
Thx
