Miked2
Jan 08, 2022Apprentice
R7000 Firmware Version 1.0.11.130 - Just showed up Jan 6, 2022
The release notes say only: Fixes security vulnerabilities. Anyone tried this one? I am afraid... But, I always hope they fix some of the other ongoing stuff, like the Attached Devices list m...
SDan67
Jan 18, 2022Tutor
Sadly, same behavior as others:
- Everytime I rename a device I lost access to the Router
- In order to gain access again I have to reboot.
- Almost evey 48 hours I lost access to the router until It gets rebooted
- Below two points are impacting my shared HDD, everytime the webserver chrash (lost web access to the router) I cannot get my files.
- My App on Android was working just fine on the release 1.0.11.100 and now.. the message I got is "logon timeout"
- I lost the "Amywhere" Section on the router and is not working anymore
- Peraphs a really bad quality or just Netgear trying to let us know to buy Orbit.
- Scupper1Jan 18, 2022GuideReally surprising what works for one person doesn't work for all.
Maybe different router versions or series.
I have Access Control turned on. Have you tried that, it was a recommended fix for 128, but it didn't solve the problem for me.- Bill-DJan 18, 2022Apprentice
As I mentioned above, '128 was UNstable for me when I installed it over '126 without a reset but resetting first left me with a stable '128.
Maybe that's what's needed with '130. Has anyone tried that?
- SDan67Jan 19, 2022TutorI will try to do the factory reset then install the "130"... I will update with the outcome.
