Miked2
Jan 08, 2022Apprentice
R7000 Firmware Version 1.0.11.130 - Just showed up Jan 6, 2022
The release notes say only: Fixes security vulnerabilities. Anyone tried this one? I am afraid... But, I always hope they fix some of the other ongoing stuff, like the Attached Devices list m...
mauryfrench
Feb 03, 2022Aspirant
Just bought the abovementioned router a few weeks ago; and am having the same @%%$# issue that you all have talked about. Will Netgear ever work this out? I have to reset the router nightly.
Sounds like I may just be grousing before trying to return it and getting a different brand...
Portwey84
Feb 03, 2022Virtuoso
mauryfrench wrote:Just bought the abovementioned router a few weeks ago; and am having the same @%%$# issue that you all have talked about. Will Netgear ever work this out? I have to reset the router nightly.
I'll answer you with more honesty than you'll probably get from elsewhere.
First question - probably not.
Your 'grousing' isn't unreasonable and I think you've pretty much answered yourself on that. I put up with the R7000 for two years but I got rid of it because now my Wife works permanently from home, the R7000 basically just could no longer handle what it was reasonably expected to do. My Wife needs a stable WiFi connection because we don't want a fixed ethernet wire running halfway round the house. Our replacement tri-band router suffers no such issues.
