fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
New Firmware Version 1.0.5.64_1.1.88 Release Notes 1. [New Feature] Supports Smart Connect. 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the...
RMinNJ
May 24, 2016Luminary
So if mine is working without any issues and I see nothing I need here.. I'm not going to upgrade?
Are there fixes that may be important but are not listed here?
ElaineM
May 24, 2016NETGEAR Employee Retired
@RMiNJ Better check out the Bugs Fixes under the Release Notes.
- chadashcroftMay 24, 2016Aspirant
I am currently on a previous release number V1.0.6.28_1.1.83 Can I update and is it an upgrade?
- sir_bazzMay 24, 2016Apprentice
Looks good so far.
Seeing signal strength improvement on the 2.4Ghz band.
- ElaineMMay 25, 2016NETGEAR Employee Retired
chadashcroft Just a reminder, this release still does not include Arlo Support. So, if you're using that feature you will not see that on this firmware release.
However, feel free to update your firmware using the Update button on the router admin page.
