fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
New Firmware Version 1.0.5.64_1.1.88 Release Notes 1. [New Feature] Supports Smart Connect. 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the...
LeKeiser
May 27, 2016Luminary
Hello,
There is something I don't get. How's this a new firmware? 1.0.5.64_1.1.88 ?? When the "actual" is V1.0.6.26_1.1.83
Can't be a new one...
- IrvSpMay 28, 2016Master
That IS the newest OFFICIAL Firmware release. The beta you referenced was pulled and newer ones with V1.0.5.60 and .62 were released WITHOUT Arlo support and provided for improve stability which is the reason OLD Beta's were recalled and deleted from distribution.
If you require Arlo support, call NG for firmware that supports it it seems.
- LeKeiserMay 28, 2016Luminary
Since when V1.0.6.26_1.1.83 was a beta driver? It was the official driver that NG released and that many people had problem with. It's working perfect on my rig.
It's really stupid... Even if the newer driver are a step backward in terms of options, they should have upgraded the versions as it's supposed to be... V1.0.7 something... And so on.
First time I hear and see a newer driver with an older version :O
I suspect the drop back was because Arlo support was REMOVED and they worked off the LAST beta without Arlo support. Reason given was 'stability'. Normally later versions do NOT drop functions but add them, and that is probably the reason why. Need Arlo Support, call them, they seem to have a beta now with it and that will probably be in the next firmware official release.
