fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
New Firmware Version 1.0.5.64_1.1.88 Release Notes 1. [New Feature] Supports Smart Connect. 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the...
larrypoz
May 28, 2016Aspirant
Elaine, after reading R7000 firmware updates posts I am confused.... I currentmly have V1.0.6.28_1.1.83. Are you saying to revert back to 1.0.5.64...?
BOZGBOZG
May 28, 2016Star
larrypoz
If you're not having any issue then it really depends on whether you can be bothered reverting back. The main issue is that if problems do emerge, your firmware is no longer supported.
