fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
New Firmware Version 1.0.5.64_1.1.88 Release Notes 1. [New Feature] Supports Smart Connect. 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the...
tomdz
May 28, 2016Aspirant
I've noticed that GUI Language Versions reads V1.0.6.28_2.1.38.2 after upgrading to this firmware, is this expected? Firmware Version gives the correct number.
- IrvSpMay 28, 2016Master
tomdz wrote:I've noticed that GUI Language Versions reads V1.0.6.28_2.1.38.2 after upgrading to this firmware, is this expected? Firmware Version gives the correct number.
Not sure what you are looking at? I see this:
Did you RESET the router after install the firmware?
- smartloomMay 28, 2016Guide
Does this firmware have time sync fix? I am running V1.0.5.49_20151208_timesync firmware. Want to make sure before upgrading.
- tomdzMay 29, 2016Aspirant
Router information in Advanced Home at routerlogin.net.
Yes.- IrvSpMay 29, 2016Master
When you upgraded, how did you setup the settings? Manually or load a settings backup file?
In any event it is possible the firmware load had a problem. I'd ERASE (Advanced, Administration, Backup Settings) the firmware settings and do the reset to default that way and THEN re-load the firmware (d/l it again to be safe) and install it. Then re-enter all your settings. I guess you could see if the version are correct before even re-entering the settings.
