fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
New Firmware Version 1.0.5.64_1.1.88 Release Notes 1. [New Feature] Supports Smart Connect. 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the...
Inkster
Jun 09, 2016Aspirant
Hi All
After upgrading to R7000-V1.0.5.64_1.1.88 from R7000-_V1.0.3.80-1.1.38 this week I am experiencing lots of disconnections from the Internet on both 2.4 & 5 wireless modes and LAN ports. When I check the logs it show every 15min or 30mins [Internet connected] IP address: XXX.XX.XXX.XXX, Thursday, Jun 09,2016 13:10:59. I have done all my checks (Like connect straight to the modem) and flashed the firmware in the correct way (Factory reset, manual config and power cycle). I must admit that l had the odd one or two disconnections with the previous firmware that's why I did the upgrade but it seems worse now. I am more concern with a stable connection rather than bells and whistles could someone advice me on a stable firmware to use for now until Netgear sorts this 3 year old problem out on what I see from reading the forums. My two laptops which one is connected to the LAN and the other on 2.4 wireless and four android devices which two are on 5 wireless and the others on 2.4 wireless are all suffering from the same symptom.
- IrvSpJun 09, 2016Master
Inkster wrote:Hi All
I'm getting things like that too, and it has been getting worse and I've reported it to ElaineM. However mine all look like this:
[Time synchronized with NTP server] Wednesday, Jun 08,2016 19:51:40 [Internet connected] IP address: My Wan IP Address is here, Wednesday, Jun 08,2016 19:51:40
My IP Address is showing but I never see a DISCONNECT? This started in the last few days it seems. Before that it was basically every 14 hours or so it sync'ed the time. Now I'm down to 1 1/2 hour or so intervals:
[Time synchronized with NTP server] Tuesday, Jun 07,2016 02:53:44 [Internet connected] IP address: 1xxxxx0, Tuesday, Jun 07,2016 02:53:44 [Time synchronized with NTP server] Tuesday, Jun 07,2016 01:08:44 [Internet connected] IP address: 1xxxxxxxx0, Tuesday, Jun 07,2016 01:08:44 [Time synchronized with NTP server] Monday, Jun 06,2016 23:23:44 [Internet connected] IP address: 1xxxxxx0, Monday, Jun 06,2016 23:23:43 [Time synchronized with NTP server] Monday, Jun 06,2016 21:38:44 [Internet connected] IP address: 1xxxxxx0, Monday, Jun 06,2016 21:38:43 [Time synchronized with NTP server] Monday, Jun 06,2016 19:53:44
Before this the time sync's looked like this:
[Time synchronized with NTP server] Thursday, Jun 02,2016 11:53:19 [Internet connected] IP address: 1xxxxxxx0, Thursday, Jun 02,2016 11:53:18 [Internet disconnected] Thursday, Jun 02,2016 11:53:17
I do NOT see the DISCONNECTED in the logs anymore. I do NOT experience drops either from what I can tell, but if the old log right above is correct it is only a second or two, but maybe the PC re-connect takes longer? However in NO case did I see a re-connect immediately after the INTERNET CONNECTED entry?
I'm wondering if there was a change on some internal time server NG is using?
- bigdpsJun 09, 2016Aspirant
That was the same with me except only 5G would stay connected. The router even would forget I was connected to it as my network adapter settings would tell me I had a disconnected cable when I would lose connection.
I think that 1.0.5.64 version is bug ridden. How come nobody from Netgear will chime in? Because they know it is broken and are lost as to what to do?
- AntonK_58Jun 09, 2016Tutor
I've had no problems with the latest firmware. The variety of experiences with it is mind-boggling to me. I wonder would could account for such variety?
