fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
New Firmware Version 1.0.5.64_1.1.88 Release Notes 1. [New Feature] Supports Smart Connect. 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the...
rve52001
Jun 19, 2016Aspirant
Does 1.0.5.70 fix the GUI not changing? I had the same problems as some where when I downgraded from 1.0.6.40 to 1.0.5.64 the GUI stayed at 1.0.6.40-2.1.38.1. The funny thing is I was having strang wireless issues untill I put 1.0.6.40 back on. So was wondering if anyone downgraded to 1.0.5.70 without any issues? And yes I reset my modem each time and manually changed settings each time I allways update my modem.
bigdps
Jun 20, 2016Aspirant
I don't know about your problems but for me, going to 1.0.5.70 fixed my nightmares.
- rve52001Jun 20, 2016Aspirant
I was having speed issues on my wireless 2.5Ghz. My speeds were all over the place. I think it had to do with trying to downgrade firmware and the GUI staying the same version no matter which firmware I tried.
- bigdpsJun 20, 2016Aspirant
Have you tried the 1.0.5.70 on your router? That's the one that worked for me.
Not yet, but before I did, I was was inquiring to see if it fixed the GUI not changing before I did? I didn't want to go through all the trouble with resetting and reconfiguring everything if it didn't work for others. I had a suspicion it had to do with the GUI staying the same when downgrading to 1.0.5.64.
