fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
New Firmware Version 1.0.5.64_1.1.88 Release Notes 1. [New Feature] Supports Smart Connect. 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the...
bigdps
Jun 20, 2016Aspirant
Have you tried the 1.0.5.70 on your router? That's the one that worked for me.
rve52001
Not yet, but before I did, I was was inquiring to see if it fixed the GUI not changing before I did? I didn't want to go through all the trouble with resetting and reconfiguring everything if it didn't work for others. I had a suspicion it had to do with the GUI staying the same when downgrading to 1.0.5.64.
- bigdpsJun 21, 2016Aspirant
Well for me, it did a whole lot of difference. One thing I did and it usually isn't recommended was I saved the configuration before I updated the firmware. I know we are supposed to start from scratch but in my case, I had done it way too many times. Long story short, after saving the cfg file and updating the firmware, yes it cured all my problems. Yes the GUI is updated to the latest firmware but all is good. I don't careless if there is a newer update as I won't install it. Working on a network probleem for a week is counter productive. Right now it is solid again and I want it to stay like that.
Hope you find the same success as I did.
