chemasi
Jan 01, 2016Aspirant
R7000 Firmware Version 1.0.6.28 - strange 3rd SSID
The latest firmware update for the R7000 is creating an second 2.4GHz named NETGEAR47-arlo_*random numbers*. I have a separate 2.4 GHZ and 5GHz network that I am already using. I downgraded the r...
- Jan 01, 2016
YES! I'm seeing the same thing.
Look in the Router Settings, Left Column, ARLO: You can enable/disable.
The Help Link states the following:
Arlo
You can turn your router into an Arlo base station by enabling Arlo on your router.
After you enable Arlo on your router, you can sync your Arlo cameras to your router.
NOTE: Enabling Arlo will cause the router to broadcast an Arlo SSID, in addition to the router’s SSID. The Arlo SSID can be used only by the Arlo cameras.
chemasi
Thanks, this is the solution. I was looking in the advanced tab instead of the basic tab.
knetje
Jan 02, 2016Initiate
I'm seeing the same thing on the 2.4GHz band, after the update to 1.0.6.28 firmware. Unfortunately, I cannot switch it off. I'm only using the 5GHz band and don't want to have an additional 2.4GHz network. I've tried disabling Arlo but that didn't help. Rebooted, checked the wireless settings, but nothing turned off the Arlo SSID.
- chemasiJan 02, 2016AspirantMaybe a bit obvious, but did you press on apply?
- Obi43Jan 02, 2016Initiate
There is a bug with this firmware, when you disable 2.4G wifi the Netgear ARLO wifi starts. Unckecking "ARLO enable" does not solve this problem. By now only solution is install previous firmware.
- KillhippieJan 06, 2016Prodigy
That might be by design oddly enough, if you have arlo and dont use 2.4Ghz it may broadcast arlo so the cameras stay connected when 2.4 is disabled permantly, just a guess.
