FvAT's avatar
FvAT
Tutor
Oct 08, 2017
R7000 Firmware Version 1.0.9.10 frequently disconnects devices on 5GHz band
I just upgraded the router from firmware ..9.6 to 9.10. However I find that the router frequently disconnects devices connected on the 5GHz band. If I connect such a device to 2.4 and then back to 5 ...
  • FvAT's avatar
    FvAT
    Dec 05, 2017
    1.0.9.12 fixed it.
