FvAT
Oct 08, 2017Tutor
R7000 Firmware Version 1.0.9.10 frequently disconnects devices on 5GHz band
I just upgraded the router from firmware ..9.6 to 9.10. However I find that the router frequently disconnects devices connected on the 5GHz band. If I connect such a device to 2.4 and then back to 5 ...
- Dec 05, 2017
1.0.9.12 fixed it.
xrcd
Dec 04, 2017Aspirant
I have exactly the same problem. No, I didn't factory reset, but what are the chances that two different users get the exact same random problem because of this this? Would be nice if sbdy from Netgear would investigate and come up with a clear answer instead.
michaelkenward
Dec 04, 2017Guru - Experienced User
The first thing that Netgear's team will tell you to try is a reset. Don't do it and they can't really fulfill your request for a clear answer.
xrcd wrote:
...but what are the chances that two different users get the exact same random problem because of this this?
The chances are very very high if that is what it takes to fix the problem.
- VolstateDec 04, 2017Apprentice
If the problem resurfaces (and it most likely will) then disable 5GHZ and run strictly 2.4....since I did that days ago I have had no disconnects at all. I hope netgear gets this fixed...
- FvATDec 05, 2017Tutor
1.0.9.12 fixed it.
- michaelkenwardDec 05, 2017Guru - Experienced User
Thanks for that report.
Nice to know that fresh firmware hasn't caused more grief than joy.
Let's hope it works for other people.
