sktn77a's avatar
sktn77a
Virtuoso
Apr 05, 2020
R7000 Firmware Version 1.0.9.60 and above still require changing default password?
When I updated my R7000 router to Firmware Version 1.0.9.60 I was forced to change the default password from "password" to something else.  I really don't care to do this so I went back to the previous firmware version.  Does anybody know if this is still required for the latest firmware update (v1.0.11.100)?
Don't really want to debate the merits of changing the password from the default, just want to know if I'm still required to change it with the latest firmware.
Thanks in advance.
  • sktn77a's avatar
    sktn77a
    Apr 05, 2020
    "Yes, and for good reasons. But if you're thick-headed, stay at your current firmware version":
    But security clearly does not matter to someone who leaves a gaping great hole in their system by sticking with the "out of the box" settings.
    ^^^^^^^  Just the kind of responses I was trying to avoid.  I guess that's what the internet does to people.
    Forget it, I'm outa here.
  • Yes, and for good reasons. But if you're thick-headed, stay at your current firmware version
    • michaelkenward's avatar
      michaelkenward
      One reason for updating firmware is that it often tightens up on the router's security. That is one of the claims made in the new firmware for the R7000.
      R7000 Firmware Version 1.0.11.100 | Answer | NETGEAR Support
    • sktn77a's avatar
      sktn77a
      Virtuoso
        michaelkenward
        Oh dear, another one who refuses to move into the real world.
        Ask a silly question get silly answers.
        Three people say it won't work, they are clearly all wrong.
  • Hi Keith,
    With all the emphasis on security I doubt that would be an option.
    1. I haven't read the manual, but check for an option to disable password login.
    2. Try changing the password to "password" if possible, I think that's the default PW
    3. Choose a very simple password like, 00000000, 11111111, 12345678, netgear, passwords, etc.
