Sa9aX11
May 17, 2016Guide
R7000 Firmware
Hi Is V1.0.6.40_1.1.90 the latest firmware for R7000? Sal
- May 17, 2016
No, that one and all the original beta's have been pulled due to stability problems. A new set of beta's have been released with lower numbers and no Arlo support.
The most recent is https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-62/td-p/1078114 and if you apply it, since you have a later version you should RESET the router after application and re-enter all settings manually.
IrvSp
May 17, 2016Master
Sa9aX11
May 24, 2016Guide
Hi
Now I am not too sure which version I should use to update my R7000, I hear this R7000-V1.0.5.64_1.1.88 version is a new update and then there is the beta version R7000-V1.0.5.62_1.1.87.
Which one I should use?
Do I really need to wipe off all my settings to factory default after the update? Can I just restore my router backup?
Sal.
- IrvSpMay 24, 2016Master
Sa9aX11 wrote:Hi
Sal.
The V1.0.64 is an Official release, the other is a Beta. Probably the official release is the beta but you can't be sure it doesn't have some fixes in it. There is a FIX LIST on the link to get the file.
Since it seems you have a version that is numbered higher than either of the two listed you should reset and re-apply (not load a saved settings backup) your setting. People whom have NOT done this have experienced problems going backwards with releases.
Yes since you are coming from V1.0.6. Manually re-enter the settings.
- Sa9aX11May 24, 2016Guide
I have updated my R7000 to V1.0.5.64_1.1.88 but there no Arlo page in this version, how do I activate my Arlo Cam thru the router, I don't have the base, the old firmware version had did and it worked great. The only thing I see in the new version firmware the Arlo Cam shows is active on the "Attached Device" page, the Arlo Web Portal tells me its offline, I've set it up as a new device (Arlo) but it failed, just can't find the device, I removed all the devices on Arlo Web Portal to start all over again, as new device Router (not base) and now it can't find my router.
Sal
- IrvSpMay 25, 2016Master
This official release does NOT support Arlo, only the old recalled beta's did.
