HTCSystems
Nov 21, 2022Tutor
R7000 Firmware
I have a R7000 running firmware 1.0.11.126. It should be getting 240mb download. It keeps dropping to 80mb download. Research indicates it is a firmware issue. I have downloaded 1.0.11.136 and tri...
Nov 21, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How are you connected to the router? Wireless or wired? Wired is preferred for speed testing.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
How is wireless settings configured?
Is Smart Connect enabled or disabled?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What security modes are you using? WPA2/AES Only is best.
- HTCSystemsNov 21, 2022Tutor
I have done all of the power cycling and resets. Sounds like the only fix is to reset to factory defaults, install latest firmware. Correct? What a pain, I should not have to go through this. Will it actually fix the issues?
- KitsapNov 21, 2022Master
HTCSystems wrote:I have done all of the power cycling and resets. Sounds like the only fix is to reset to factory defaults, install latest firmware. Correct? What a pain, I should not have to go through this. Will it actually fix the issues?
Yes it is a pain. The track record of the default reset resolving issues is good. No guarantee it will fix your issue. You could also have line issues feeding problems to your un-named modem/ONT.
When you get it working, then save a backup configuration file and note the firmware version it was created under. Makes restoring the settings less painful.
- michaelkenwardNov 21, 2022Guru - Experienced User
For real fun, make a backup before installing the new firmware.
After the update, reload the old settings.
If you are lucky, the problem will go way.
If not, which is likely, just reset the thing again and don't restore the settings.
- plemansNov 21, 2022Guru - Experienced User
What research makes you think its a hardware issue?
We don't know what you're testing on, if you're testing over wireless, over 2.4ghz/5ghz?
Some details of your setup, what you're testing with, how you're testing, and even the app/test site help us to help you.
Plus the modem/gateway.
You can always make a backup of the current setup. Try the factory reset and test its speeds. If it works, then reinstall the backup and test the speeds. See if something in the settings is corrupt causing the issue.
