HTCSystems
Nov 21, 2022Tutor
R7000 Firmware
I have a R7000 running firmware 1.0.11.126. It should be getting 240mb download. It keeps dropping to 80mb download. Research indicates it is a firmware issue. I have downloaded 1.0.11.136 and tri...
Kitsap
Nov 21, 2022Master
HTCSystems wrote:I have a R7000 running firmware 1.0.11.126. It should be getting 240mb download. It keeps dropping to 80mb download. Research indicates it is a firmware issue. I have downloaded 1.0.11.136 and tried to install it. The install starts and runs for about 15 seconds, the it says session closed. How do I get the current firmware installed.
Start here: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Be sure and clear the cache on your web browser before you start the process. You might need to do a firmware default reset and router configuration from scratch after installing the update. Do not import a previously saved configuration file.
What is the brand name and model number of the modem you are connecting your R7000 to?
