plegrand
Apr 17, 2023Tutor
R7000 Firmware
Hello, I have had a R7000 wifi router for a while now. For some time now I have been experiencing a lot of problems with it (frequent disconnections) The problems came with the successive updates ...
Apr 17, 2023Guru - Experienced User
The latest version has been pretty solid.
If both .42 and the .136 version have had the same issue, I wouldn't suspect the firmware.
I'd be more thinking interference or hardware failure if its specific to one band.
plegrand
Apr 17, 2023Tutor
I will test the latest version this evening with hard reset before and after upgrade by downloading the latest version from here:
https://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.11.136_10.2.120.zip
Is it the good procedure ?
Nothing else to do when upgrading ?
I will have a look to the wifi channel for the 2.4ghz
I will tell you the result tomorow
Thanks again
- plegrandApr 17, 2023Tutor
And in the case of an equipment replacement, what would you advise me? Not necessarily from the netgear brand đ
- FURRYe38Apr 17, 2023Guru - Experienced User
I had good luck with v.134 with my R7000 when i had it online last year. Worked well:
Might go thru this and see if the configuration I used help. I use manual channels and Smart Connect is enabled along with Beamforming and MIMO.
I also keep a laptop cooler fan running under any router I put online.
- KitsapApr 17, 2023Master
After you perform a firmware default reset, you will have to set the configuration of your R7000 back to AP mode.
THen, you recommend this firmware version? (134)
What would be the exact procedure for this update?this one looks good to you?
Unplug my box from the router Unplug my box from the power supply Hard reset of the router Router update Hard reset of the router Router configuration Turn off the router Connect the box to the power supply Wait for it to start up completely Connect the router to the box Restart the routerAnd if you had to advise me a replacement router, which one would you recommend? (not necessarily netgear by the way)
Thanks for your help
- plegrandApr 18, 2023Tutor
