plegrand
Apr 17, 2023Tutor
R7000 Firmware
Hello, I have had a R7000 wifi router for a while now. For some time now I have been experiencing a lot of problems with it (frequent disconnections) The problems came with the successive updates ...
plegrand
Apr 17, 2023Tutor
I will test the latest version this evening with hard reset before and after upgrade by downloading the latest version from here:
https://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.11.136_10.2.120.zip
Is it the good procedure ?
Nothing else to do when upgrading ?
I will have a look to the wifi channel for the 2.4ghz
I will tell you the result tomorow
Thanks again
plegrand
Apr 17, 2023Tutor
And in the case of an equipment replacement, what would you advise me? Not necessarily from the netgear brand đ
