plegrand
Apr 17, 2023Tutor
R7000 Firmware
Hello, I have had a R7000 wifi router for a while now. For some time now I have been experiencing a lot of problems with it (frequent disconnections) The problems came with the successive updates ...
plegrand
Apr 17, 2023Tutor
I will test the latest version this evening with hard reset before and after upgrade by downloading the latest version from here:
https://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.11.136_10.2.120.zip
Is it the good procedure ?
Nothing else to do when upgrading ?
I will have a look to the wifi channel for the 2.4ghz
I will tell you the result tomorow
Thanks again
Apr 17, 2023Guru - Experienced User
I had good luck with v.134 with my R7000 when i had it online last year. Worked well:
Might go thru this and see if the configuration I used help. I use manual channels and Smart Connect is enabled along with Beamforming and MIMO.
I also keep a laptop cooler fan running under any router I put online.
- KitsapApr 17, 2023Master
After you perform a firmware default reset, you will have to set the configuration of your R7000 back to AP mode.
- plegrandApr 17, 2023Tutor
THen, you recommend this firmware version? (134)
What would be the exact procedure for this update?this one looks good to you?
Unplug my box from the router Unplug my box from the power supply Hard reset of the router Router update Hard reset of the router Router configuration Turn off the router Connect the box to the power supply Wait for it to start up completely Connect the router to the box Restart the routerAnd if you had to advise me a replacement router, which one would you recommend? (not necessarily netgear by the way)
Thanks for your help
- plegrandApr 18, 2023Tutor
I am also advised to turn to wifi mesh.
Not knowing anything or not much about it, I understand that for "efficient" wifi mesh, i have to choose "tri-band".Thank you for your help and your opinions
- plemansApr 18, 2023Guru - Experienced User
Your not going to get much on other manufacturers since this is the netgear forum.
Your best bet is to read a few reviews and blogs where they actually test them.
- FURRYe38Apr 18, 2023Guru - Experienced User
Worth a try for sure and see.
Otherwise, Give a RAX30 a try or something RAX.The R series line of router is getting up in age and probably wont see much more FW updates in the future. NG can only do so much to keep those models running.
RAX model line would be something to take a look into. I have a RAX50v2 and works well. I recently acquired a RAX120v2. Works well in AP mode.
I got a RAX30 for work needs however I haven't used it much. Can try something and give it a go and if it doesn't work, send it back to the seller if they have a good refund policy.
- KitsapApr 18, 2023Master
plegrand wrote:I am also advised to turn to wifi mesh.
I do not know where your advice or understanding is coming from. The tri-band part is suspicious.
To cut through bad advice and marketing hype, an outstanding reference document can be found here:
https://www.duckware.com/tech/wifi-in-the-us.html
Do not try to digest it all at once. Pick your topics. There is a section on tri-band.
Whom told you to turn off MESH?
MESH only comes in certain router systems, Like NGs Orbi or MK systems, are MESH systems. Router with remote satellites for extended coverage though out the home. Other NG routers like R, RAX RAXE and XR series are NOT MESH systems nor support MESH features.
You don't have to have tri band for MESH though it has it's advantages. NGs MK60 series is a dual band MESH system, not tri band. MK70 and 80 and Orbi systems are Tri-bands. The 3rd radio is mostly a dedicated wireless backhaul connection between the router and satellite.
- michaelkenwardApr 18, 2023Guru - Experienced User
Oh so true.
Treat it with extra suspicion if it came from the ISP's tech support. They will cook up any story to pass the buck back to the user and their equipment.
Hello,
after my problems with the latest version (136) I downgraded the firmware to version 1.0.9.42.
With this version, I still had some strange problems.
- My printer connected well to the router's wifi, got an IP address from my box, but was not visible on the network (no ping)
- 2 "special" devices (alarm interface and boiler interface) were not working at all.
- The rest was working properlySo I made an update to the "last" version proposed on the web interface of the router (1.0.9.88) without hard reset before or after the update.
After this update, everything seems to work correctly.
I will wait a little while before rejoicing.
If I encounter problems again I will try to update to more recent versions (126, 128, 130, 134)I am surprised to have encountered problems with 1.0.9.42 which seemed to be the most secure, while 1.0.9.88 is not necessarily unanimous.
I keep in mind the RAX30 solution that I had also spotted just in case.
As well as a solution based on wifi meshThanks again for your advice and help.
Pascal
