plegrand
Apr 17, 2023Tutor
R7000 Firmware
Hello, I have had a R7000 wifi router for a while now. For some time now I have been experiencing a lot of problems with it (frequent disconnections) The problems came with the successive updates ...
Apr 17, 2023Guru - Experienced User
I had good luck with v.134 with my R7000 when i had it online last year. Worked well:
Might go thru this and see if the configuration I used help. I use manual channels and Smart Connect is enabled along with Beamforming and MIMO.
I also keep a laptop cooler fan running under any router I put online.
Kitsap
Apr 17, 2023Master
After you perform a firmware default reset, you will have to set the configuration of your R7000 back to AP mode.
