hexcei
Jan 30, 2021Guide
R7000 FW 1.0.11.116 NTP / Router PIN
Hi, Was curious if anyone has these issues. 1. Manually updating NTP preffered server does not appear to reatin setting. 2. Unchecking "Enable Router's PIN" does not retain. Thanks! ...
mpoc
Feb 26, 2021Aspirant
I have the same router, and noticed the same problem. It's kind of annoying. I would like to disable WPS completely, but apparently that's not an option, or just doesn't save the setting.
