routerNewby1
May 28, 2024Aspirant
R7000 fw V1.0.11.126_10.2.112 fails to connect to internet when set for Static IP
My Fiber ISP provider assigned me one static IPv4 address. I am attempting to configure the Netgear R7000 router (WAN not LAN) IP address for the Internet connection. The R7000 used as simple rout...
- Jun 05, 2024
I tried the sequence suggested by FURRYe38 but that did not help. So the ISP sent their technician to the site who confirmed that the problem was with the particular IP address they had assigned. They provided and provisioned a different IP address, and that solved the problem. It worked without needing to cycle power on the Fiber Modem or the Netgear R7000 router. So, the bottom line is that the issue was with the ISP, not the router. So my problem is solved. FURRYe38 Thank you for chiming in with your suggestion.
May 28, 2024Guru - Experienced User
If the ISP doesn't required PPPoE account configuration, then use only DHCP for the Internet configuration.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
