leonid32
Nov 19, 2017Tutor
R7000 goes straight to http://192.168.1.1/MNU_access_setRecovery_index.htm
Hi! My Nighthawk R7000 suddently started to go to http://192.168.1.1/MNU_access_setRecovery_index.htm every time I try to access it from any computer, connected to it - WiFi or wired. Even if I exp...
- Nov 22, 2017
Hi leonid32,
Try to reset the router to factory default.
JamesGL
Nov 22, 2017NETGEAR Employee Retired
Hi leonid32,
- JamesGLNov 26, 2017NETGEAR Employee Retired
Hi leonid32,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- leonid32Dec 02, 2017Tutor
Sorry for the long delay, I was away from home for a while.
Yes, factory reset did resolve the problem; however, I feel that I cannot rely on R7000, so I purchased 2-point Google WiFi mesh, and installed it. It seems to give a better signal and is more stable.
- andrewkhinkleSep 30, 2018Tutor
I have also Bought Google WiFi Mesh recently.. Just wanted to know Which Gateway did you use to configure your WiFi Router. I tried with 192.168.1.1, But Didnt work!! :smileysad:
