leonid32
Nov 19, 2017Tutor
R7000 goes straight to http://192.168.1.1/MNU_access_setRecovery_index.htm
Hi! My Nighthawk R7000 suddently started to go to http://192.168.1.1/MNU_access_setRecovery_index.htm every time I try to access it from any computer, connected to it - WiFi or wired. Even if I exp...
- Nov 22, 2017
Hi leonid32,
Try to reset the router to factory default.
JamesGL
Nov 26, 2017NETGEAR Employee Retired
Hi leonid32,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
leonid32
Dec 02, 2017Tutor
Sorry for the long delay, I was away from home for a while.
Yes, factory reset did resolve the problem; however, I feel that I cannot rely on R7000, so I purchased 2-point Google WiFi mesh, and installed it. It seems to give a better signal and is more stable.
- andrewkhinkleSep 30, 2018Tutor
I have also Bought Google WiFi Mesh recently.. Just wanted to know Which Gateway did you use to configure your WiFi Router. I tried with 192.168.1.1, But Didnt work!! :smileysad:
- leonid32Sep 30, 2018Tutor
To the best of my knowledge, the only way to configure it is to download and run Android or iPhone application for that. It will guide you through the configuration process. At least, that's what I did.
The address to the router is 192.168.86.1 , but it just gives you links to the Google WiFi application download.
