MC72
Nov 17, 2020Aspirant
R7000 goes straight to http://192.168.1.1/MNU_access_setRecovery_index.htm
Hi all - I stupidly upgraded my firmware using wifi instead of flashing it manually (which I'll do from now on!) since I rebooted post-upgrade, it lets me use my username/password for router security...
MC72
Nov 21, 2020Aspirant
Any ideas? I've answered all your questions to the best of my knowledge. Did I miss any?
I'm using the default creds which the router admin window accepts then it sends me to a page asking for the router serial, which I enter correctly and it gives an error message saying "162.168.1.1 says The serial number entered does not match the value on the router, try again" (sic). Are we stalemated here?
antinode
Nov 21, 2020Guru
> [...] held the reset button for just over 10 seconds. No changes in
> the LED lights any of the times I tried it. [...]
Not a good sign. You might try again, but with no connections to the
R7000 other than its power adapter. If the Reset button does not cause
a reset (evidenced by LED activity), causing the R7000 to accept its
default "admin" credentials, then there's a bigger-than-usual problem.
The fact that it doesn't like the serial number from the label also
suggests some kind of hardware problem or firmware corruption.
> [...] It's still accepting default creds (admin / password) but
> persists in the serial number dead end I've described.
That's what I'd expect _rejecting_ the credentials to look like. The
serial-number request is part of the (often defective) password-recovery
scheme. If you put in any bad set of credentials, does it do anything
different?
If you can't get it to do a proper settings reset, then you might try
to find a way to entice it into letting the TFTP recovery scheme cram a
fresh firmware image into it. That might require some lucky timing, or
unusual power-on/Reset sequencing. No bets on whether it's possible,
but you might have little to lose by playing around with it.
- MC72Nov 21, 2020AspirantAll is well - I used a USB-TTL cable and putty to put it into recovery mode and then was able to flash a new firmware image through Ethernet cable through TFTP.
Running great now :)
Thanks for the advice!
