Michaeal
Sep 20, 2024Aspirant
R7000 half internet speed (upload 600, download only under 300)
I have some issue with r7000. my download speed was limited under 300 mbps. I have try fw 0.42, and many other fw but cannot fix this issue. I have off QOS. current fw is 0.216. anybody have ...
Sep 20, 2024Guru - Experienced User
If you ever had parental controls, access controls, qos, or traffic monitoring on, factory reset and reinstall.
Make sure not to enable those services.
Then test it.
