Michaeal
Sep 20, 2024Aspirant
R7000 half internet speed (upload 600, download only under 300)
I have some issue with r7000. my download speed was limited under 300 mbps. I have try fw 0.42, and many other fw but cannot fix this issue. I have off QOS. current fw is 0.216. anybody have ...
Michaeal
f6600pr7000I have do factory reset but it still not working
I take a result from F6600p zte (picture 1)
I don't known what wrong but seem they limited download speed around 300mbps (picture 2)
look like they had limited, but I off all feature QOS, parent control, access control already
Sep 22, 2024Guru - Experienced User
What is the brand and model# ISP Modem or ONT the router is connected too?
Here is my R7000 results connected to a NG CM3000 cable modem:
Wired PC behind the R7000:
R7000 onboard speed test which has always never been accurate:
No Armor, Access Cntrols, Circle, Traffic Meter enabled.
FW updated and factory reset and setup from scratch.
